Software Customisation
Object Type Details
: VIEW Gadget: ALPHA Views
Members
Name
Type
Purpose
Channel
STRING Get/Set
Get or set the assigned channel.
Table 2: 133.
VIEW ALPHA Object Members
Methods
Name
Result
Purpose
Clear()
NO RESULT
Clear all lines from the Alpha TTY window.
Refresh
NO RESULT
Refreshes the display of the gadget.
SetFocus()
NO RESULT
Set the keyboard focus immediately to this Alpha gadget.
removeRequests()
NO RESULT
Deletes the ‘requests’ channel from the alpha view gadget, and dissociates it from the current Requests IO-channel if necessary.
Background()
STRING
Get Background Colour Name.
Some gadgets do not support this property in all circumstances, e.g. gadgets which are showing a pixmap. Gadgets whose colour has not been set explicitly, may not have a colour with a known colourname. In this case an error is raised..
Table 2: 134.
VIEW ALPHA Object Methods
Command
The VIEW ... ALPHA command puts you into View Setup mode. You remain in View Setup mode until you use the EXIT command.
(ALPha)--+- <vshap> -----------------------------------. |
+- CHANNEL -+- COMMANDS -----------------------| |
| ‘- REQUESTS -----------------------‘- NL -*
‘-- EXIT -->
Figure 2:68.
Syntax Graph -22: Setting Up an ALPHA VIEW Object
