Software Customisation
Object Type Details
: TOGGLE Gadget
TOGGLE Gadget
Member
Name
Type
Purpose
Val
BOOLEAN Get/Set
Toggles value between TRUE and FALSE.
Methods
Name
Result
Purpose
AddPixmap(STRING file1, STRING file2, STRING file3 )
AddPixmap(STRING file1, STRING file2)
AddPixmap(STRING file )
NO RESULT
Adds pixmaps to be used for the unselected, selected and inactive states. The last two are optional.
FullName()
STRING
Get the full gadget name, e.g.'!!Form.gadget'.
Name()
STRING
Get the gadget's name, e.g. 'gadget'.
Owner()
FORM
Get owning form.
SetFocus()
NO RESULT
Moves keyboard focus to this gadget.
SetPopup(MENU)
NO RESULT
Links the given menu with the gadget as a popup.
RemovePopup(MENU)
NO RESULT
Removes the given popup menu from the gadget.
GetPickedPopup()
MENU
Returns the last picked popup menu for the gadget.
Refresh()
NO RESULT
Refreshes the display of the gadget.
Shown()
BOOLEAN
Get ‘shown’ status.
SetToolTip
STRING
Sets or edits the text of the TOOLTIP.
Type()
STRING
Get the gadget type as a string.
Background()
STRING
Get Background Colour Name.
Some gadgets do not support this property in all circumstances, e.g. gadgets which are showing a pixmap. Gadgets whose colour has not been set explicitly, may not have a colour with a known colourname. In this case an error is raised..
Table 2: 126.
TOGGLE Object Methods
Command
The TOGGLE command defines a toggle gadget, and specifies its position, tag, and callback text. Also allows you to specify different text strings for the default ON and OFF states.
You can define the TOGGLE to be either PML-controlled, or core-code controlled using the gadget qualifier attribute
control type
, with values ‘PML” or “CORE”.
>- TOGGLE gname -+- <fgtagw> -----------|
+- PIXMAP <vshap> -----|
+- CALLback text —-----|
+- <fgpos> ------------|
+- <fganch> -----------|
+- TOOLTIP text -------|
+- CORE ---------------* Core managed gadget
+- STATES text1 text2 -.
‘----------------------+- TOOLTIP text -.
Figure 2:67.
Syntax Graph -: Setting Up a TOGGLE Object
where
text1
corresponds to the OFF setting and
text2
corresponds to the ON setting.
It is bad practice to place one gadget on top of another. This may lead to gadgets being obscured.
Default:
Default text strings for the two toggle settings are ‘OFF’ and ‘ON’.
Default state when a toggle is first defined is ‘OFF’; i.e. button raised.
Pixmaps associated with Toggle gadgets can be changed after the gadgets have been displayed on a form.
Method syntax:
AddPixmap( !pixmap1 is STRING )
AddPixmap( !pixmap1 is STRING, !pixmap2 is STRING )
Where: !pixmap is a string holding the file pathname of the required .png file, e.g.
!pixmap1 shows the Un-selected state of the gadget, and pixmap2 shows the Selected state.
Notes:
1.
It is recommended that when you define the gadget you set its size to encompass the largest pixmap which you will later add. Failure to do this may give rise to unexpected behaviour.
2.
Historically you could add a third pixmap which was used when the gadget was de-activated. This practice is no longer necessary as the gadget pixmapped is automatically greyed-out on de-activation.
