Software Customisation
Object Type Details
: TEXTPANE Gadget
TEXTPANE Gadget
Members
Name
Type
Purpose
Val
ARRAY OF STRING Get/Set
Get or set the contents of the text pane.
Count
REAL Get Only
Get the number of lines of text in the gadget.
Table 2: 124.
TEXTPANE Gadget Members
Methods
Name
Result
Purpose
FullName()
STRING
Get the full gadget name, e.g.'!!Form.gadget'.
Name()
STRING
Get the gadget's name, e.g. 'gadget'.
Owner()
FORM
Get owning form.
Clear()
NO RESULT
Clear all lines from the gadget
Line(REAL )
STRING
Get the text of given line
SetLine(REAL, STRING)
NO RESULT
Replace specified line number by STRING.
CurPos()
ARRAY[2] OF REAL
Get cursor position (line, character).
SetCurPos(REAL[2])
NO RESULT
Set cursor position (line, character).
SetCurPos(REAL, REAL)
NO RESULT
SetEditable(BOOLEAN)
NO RESULT
Set edit status.
SetPopup(MENU)
NO RESULT
Links the given menu with the gadget as a popup.
RemovePopup(MENU)
NO RESULT
Removes the given popup menu from the gadget.
GetPickedPopup()
MENU
Returns the last picked popup menu for the gadget.
SetToolTip(STRING)
NO RESULT
Sets or edits the text of the TOOLTIP.
Refresh()
NO RESULT
Refreshes the display of the gadget.
Shown()
BOOLEAN
Get ‘shown’ status.
Type()
STRING
Get the gadget type as a string.
Background()
STRING
Get Background Colour Name.
Some gadgets do not support this property in all circumstances, e.g. gadgets which are showing a pixmap. Gadgets whose colour has not been set explicitly, may not have a colour with a known colourname. In this case an error is raised..
Table 2: 125.
TXTPANE Gadget Methods
Command
The TEXTPANE command defines a text pane gadget and specifies its position and tag. This is a multi-line text input field, allowing the user to enter a number of lines of text (either directly or using cut and paste). Note that no callback string is allowed with this gadget, as there is no way of knowing when a user has finished entering text.
The value of a TEXTPANE is its contents, held as an array of strings, where each line is an element of the array.
You can define the TEXTPANE to be either PML-controlled, or core-code controlled using the gadget qualifier attribute
control type
, with values ‘PML” or “CORE”.
The Textpane gadget definition has a new keyword 'FixChars' to force the use of a fixed width font. This allows the text pane to be used to show simple reports laid out using the
space
character.
The chosen font is
Courier New
(TrueType), because it has a reasonable selection of character glyphs (nowhere near as extensive as the default variable width font
Arial Unicode MS
>-- TEXTPane gname --+-- tagtext---------|
+-- <fganch> -------|
+-- <DOCK FILL> ----|
+-- <fgpos> --------|
+-- FIXCHARS -------|
+-- CORE -----------* Core managed gadget
‘-- <vshap> --->
Figure 2:66.
Syntax Graph -: Setting Up a TEXTPANE Object
It is bad practice to place one gadget on top of another. This may lead to gadgets being obscured.
