For forms of type MAIN, the QUITCALL callback is executed, if present. This permits the user to terminate the application, and so the associated PML callback should prompt the user for confirmation.
For all other form types, the QUITCALL callback is executed, if present, and then the form and its children are hidden unless the PML callback returns an error. When the form nest is hidden the CANCELCALL callback for each form of the nest is executed (in reverse display order).
Table 2: 40.
SetActive(FALSE) greys-out all gadgets on the form, but doesn’t set their Active status, so that SetActive(TRUE) restores the form to the precise state it was in before greying out, i.e. any inactive gadgets will still be inactive.
SetGadgetsActive(FALSE) greys out all gadgets on the form and sets their Active status to ‘inactive’, i.e. their previous active state is lost. Similarly SetGadgetsActive(TRUE) greys-in all gadgets and sets their Active status to ‘active’.
Table 2: 41.
SetActive()and SetGadgetsActive()can be used in combination with each other and with the Active property of individual gadgets.
+-- <form> --* form contents
1.
The callback method MUST NOT carry out any modifications to the Gadgets belonging to the form or to the Form itself (e.g. don't show or hide the form). Attempts to edit the form or its gadgets may cause unwanted side effects or possible system errors.
