Software Customisation
Object Type Details
: FMSYS Object
FMSYS Object
Methods
None of these methods modifies the original object.
Name
Result
Purpose
Checkrefs
BOOLEAN
By default, all references in a Form definition are checked when a form is displayed. Checking can be switched off, which may be recommended if
performance problems are experienced.
CurrentDocument()
FORM
This method returns the current Document of the application framework as a FORM object. If there is no current document then the returned form has value
Unset
DefaultFormat()
FORMAT
Query the system default format object for use by typed text gadgets. If none defined then returns an Unset local variable.
The returned format object is a copy, so changing it will not affect the system default format. However the user can apply it to variables e.g !text=!myVar.String(!!fmsys.defaultFormat())
DefaultFormLayout( )
STRING
query the current default form layout mode
DocsAtMaxScreen(BOOLEAN)
NO RESULT
Sets default placement position for document forms to be towards the maximum (rightmost) of the screen. Useful for wide screen ad twin screen devices.
FMINFO()
ARRAY OF STRINGS
Returns array of all FMINFO strings.
HelpFileAlias()
STRING
returns the current help file’s alias.
Interrupt()
BOOLEAN
Set to TRUE if the interrupt gadget has been selected.
LoadForm(STRING formname)
FORM
Allows force loading of a form definition and/or the ability to get a reference to a form object by name.
If the form exists then a reference to the form object is returned. If it doesn’t exist, then an attempt is made to force load its definition. If this fails then an unset form reference is returned.
Main()
FORM
Query the current main form
NoPMLUIbars()
BOOLEAN
Query the status of the main application window’s MenuBar and DialogBar. It returns true if the PML UI bars are switched off. In this case, PML Addins should not add or modify main Menus or Toolbars.
OKCurfnView(!viewtype is STRING)
BOOLEAN
Queries whether graphical views of the specified view type are displayed. Graphical view types supported are: ‘G2D’; ‘G3D’; ‘ANY’ and any view subtype is implied.
OKCurfnView(!viewtype is STRING, subtype is STRING )
BOOLEAN
Queries whether graphical views of the specified view type and subtype are displayed. Graphical view types supported are: ‘G2D’; ‘G3D’; ‘ANY’. View subtypes supported are: ‘ANY’ and for
G2D: ‘NORMAL’ (Draw); ‘PLOT’; ‘ISOSPOOL’
G3D: ‘NORMAL’ (Design)
Progress( )
REAL
Get the current Integer value in percent shown by the progress bar, in the range 0 to 100. Zero means the bars is invisible
ProgressText( )
STRING
Query the current setting of the progress bars qualifier text.
Refresh()
NO RESULT
Refresh all VIEW gadgets
SetDefaultFormat(!!fmt is FORMAT)
NO RESULT
Provide a default global format object to be used if no specific format is defined for any typed text field. Once only call, users cannot change it. !!fmt must be a global variable.
SetDefaultFormLayout(STRING)
NONE
Set the default form layout mode to 'VARCHARS' or 'FIXCHARS'.
SetHelpFileAlias(alias is string)
NONE
establishes the application help file from its alias.
SetInterrupt(GADGET)
NO RESULT
Sets the Gadget which will interrupt macro or function processing.
SetMain(FORM)
FORM
Sets the main form for an Application.
SetProgress( !percent)
NO RESULT
Set the Integer value in percent to be displayed in the progress bar. Values will be forced into the range 0 to 100. Resultant value of 0 will cause the bar to become invisible.
SetProgressText(!text is STRING )
NO RESULT
Set the progress bar's qualifier text to the specified string.
SetStatusText(!text is STRING)
NO RESULT
The text in the lower left corner of the AppWindow’s status bar is set to the specified string. This field supports application status information and you should note that some parts of the system also write to the status field, for example command prompts and cursor picking, so any information you write should be considered as transient.
Splashscreen(BOOLEAN)
NO RESULT
Removes the display of a splash screen after an abnormal exit.
StatusText( )
STRING
Returns the current AppWindow's status bar text string.
Table 2: 39.
FMSYS Object Methods
