Software Customisation
Object Type Details
: FILE Object
FILE Object
Methods
Name
Result
Purpose
File(STRING)
FILE
Create a FILE object on a file whose name is given in STRING.
AccessMode()
STRING
Return access mode for the file {‘CLOSED’, ‘READ’, ‘WRITE’, ‘OVERWRITE’, ‘APPEND}.
Close()
NO RESULT
Close file if open.
Copy(STRING)
FILE
Copies the file whose pathname is given in STRING. Returns FILE object for copied file.
Copy(FILE)
FILE
Copies the file represented by the FILE object. Returns FILE object for copied file.
DeleteFile()
NO RESULT
Delete the file represented by the file object if it exists.
Directory()
FILE
Returns a FILE object corresponding to owning directory.
DTM()
DATETIME
Returns a DATETIME object holding the date and time that this file was last modified.
Entry()
STRING
Returns file name as string.
Exists()
BOOLEAN
Returns BOOLEAN
indicating whether file exists or not.
Files()
ARRAY OF FILES
Returns an ARRAY of FILE objects corresponding to files owned by this directory.
FullName()
STRING
Returns the name including path for this FILE object as a STRING.
IsOpen()
BOOLEAN
Return BOOLEAN indicating whether file is open or not.
LineNumber()
REAL
Return line number of line about to be written.
Move(STRING)
FILE
Move this file to location given in STRING. Return FILE object for moved file.
Move(FILE)
FILE
Move this file to location represented by FILE object.
Name()
STRING
Return name of this FILE object as STRING.
Open(STRING)
NO RESULT
Opens this file in the mode given by STRING
{‘READ’,’WRITE’,’OVERWRITE’, ‘APPEND’}
Owner()
STRING
Returns the ID of this FILES owner a STRING.
Path()
ARRAY OF FILES
Returns an ARRAY of FILEs corresponding to the owning directories of this FILE object.
PathName()
STRING
Returns owning path as a STRING.
ReadFile()
ARRAY OF STRING
Open, read contents and close file. Data returned as an ARRAY of STRINGs corresponding to the lines in the file.
ReadFile(REAL)
ARRAY OF STRING
As above, but making sure that file is no longer than number of lines given in REAL.
ReadRecord()
STRING
Reads a line from an open file and returns it in a STRING. Returns an UNSET STRING if end of file is detected.
Set()
BOOLEAN
Returns a BOOLEAN indicating whether this FILE object has a name set or not.
Size()
REAL
Returns size of file in bytes.
SubDirs()
ARRAY OF FILE
Returns an ARRAY of FILE objects corresponding to directories owned by this directory.
Type()
STRING
Returns a STRING indicating whether this object represents a ‘FILE’ or a ‘DIRECTORY’.
WriteFile(STRING, ARRAY OF STRING)
NO RESULT
Opens file in mode given in string {‘WRITE’,
’OVERWRITE’, ’APPEND’}, writes STRINGs in ARRAY and closes file.
WriteRecord(STRING)
NO RESULT
Writes STRING to this FILE which must already be open.
Table 2: 38.
FILE Object Methods
