Software Customisation
Object Type Details
: COLUMNFORMAT
COLUMNFORMAT
The column object defines the way in which a column of a table object is populated.
The formatting of a column should be separate from the column definition itself and be held within the report object used to extract data from a table object. This will allow the same table to have many different reports produced from it, without the need to regenerate the table.
Methods
Name
Result
Purpose
ColumnFormat()
Constructor (initialises all the object settings)
Format(FORMAT)
Sets the format of the column to the passed format
Format(DATEFORMAT)
Sets the format of the column to the passed date format
FORMAT('STRING')
Unsets the format of the column, i.e. the column
Width (REAL)
Sets the column width
Widest()
Sets the maximum column width flag, setting a specific width value automatically sets the flag to FALSE. Note that this is the least efficient method for Width because a complete scan has to be done to determine the widest.
Indent(REAL, REAL)
Sets left and right indents (i.e. spaces) in the column
Format()
FORMAT
Returns the format for numeric values in a column
Width()
REAL
Returns the column width, strings greater than the column width are wrapped on to the next line, numeric values greater than the column width are output as a column of hashes.
GetWidest()
BOOLEAN
Returns TRUE if “widest” is set
Justification()
STRING
Returns the column justification
LeftIndent()
REAL
Returns the left indent setting
RightIndent()
REAL
Returns the right indent setting
Table 2: 26.
COLUMNFORMAT Object Methods
