Software Customisation
Gadget Syntax Graphs
: Setting Up the Gadget’s Width and Height: <vshap>
This operation allows you to set a gadget’s width and height.
>-- <vshap> --+- <vwid> ‑-+- <vhei> --------.
| +- ASPect (h/w) --|
‘- <vhei> --+- <vwid> --------.
+- ASPect (h/w) --|
Figure 2:5.
Syntax Graph -: Gadget Geometry <vshap>
h/w is the value of the Aspect Ratio (height/width).
The units for <vshap> will have been preset to pixels or F&M grid units, appropriately.
The default width and height for <vshap> will have been preset, so leaving the graph with only width or height set still realises both values.
All values may be given as integer or reals.
Setting the Height: <vhei>
>-- <vhei> -+- HEIght -.
+- LENgth -|
'- LINes --+- val -->
+- TO -+- MIN -.
| +- CEN -|
| '- MAX -'-+- <gname> -.
| +-- FORM ---|
+- <gname> -. | .---<---.
'-----------'--------------- +- * val -*-->
'- - -+--- val ---|
+-- VDIST --|
'- PADDING -*-->
Setting the Width: <vwid>
>-- <vwid> -- WIDth --+- val -->
+- TO -+- MIN -.
| +- CEN -|
| '- MAX -+- <gname> -.
| +-- FORM ---|
'-----------'--------------+- * val -*-->
'- - -+--- val ---|
+-- HDIST --|
'- PADDING -*-->
