Pipe Stress Interface
Groups Tab
: Add/Remove Members
Add/Remove Members
Member (or branch) elements are sections of a pipe, which have known start and finish points. In AVEVA E3Dâ„¢ the start and finish points are called the Head and Tail. Heads and tails may be connected to nozzles, tees or other Heads and tails, depending on the configuration of the pipe, or left open ended.
The lowest level to add to a Stress Group is a branch. Branches can be split if it is necessary to stress part of a branch.
The user can add members to a Stress Group and remove them as required. For more information, refer to
Add
and
Remove
