Pipe Stress Interface User Guide
CAESAR II to AVEVA E3Dâ„¢ : Clash Checks
The user can clash test the returned load case model from CEASAR II. To check all or individual part of the load case model. From the Load Cases Models part of the Pipe Stress Interface window, with the Output/Input tab highlighted. Select the load case to clash check from the list of load case model and select Clash Check Load Cases.
Click Close to dismiss the Pipe Stress Interface window.
