Pipe Stress Interface
CAESAR II to AVEVA E3D™
: Edit Return Nodes
Edit Return Nodes
To edit Return nodes, with the
Output/Input
tab highlighted,
select
Edit Return Nodes
A
Node Details
window is displayed containing information on the returned nodes.
The return node details window includes two new columns;
Deflection
and
Status
Deflections
set for active nodes that have been stressed and have deflection data returned to AVEVA E3D™.
Status
column is also set for active nodes. Any new nodes will be set to
New
. Deleted nodes will be set to
Deleted
and nodes which are unchanged are set to
False
