This next example illustrates a Rule Group for schematic valves. The Source Type shown below restricts this
Rule Group to being applied where the
source object is of type SCVALV.
This Rule Group has a number of nested
Rule Groups. The first has a
Condition that applies when the
source object has a valid SPRE, denoted by being not equal to
Nulref.
Create Action that specifies the type of object to be created during a
Build operation, in this case based on the attribute GTYPE of the
source object.
One of the accompanying Assign Actions copies the attribute SPRE from the
source object.
The second nested Rule Group has a
Condition that applies it when the
source object does not have a valid SPRE, denoted by being equal to
Nulref.
This Rule Group has a further nested
Rule Group that defines it as applying to
source objects with particular GTYPE values.
This Rule Group also has a
Build operation, again based on the attribute GTYPE of the
source object.
The Create Action has a
Selector which will be used during a
Build operation to select the object from the pipe specification. It will also be compared with a severity level of warning. Each
Selector has a
Question and
Answer. This
Selector takes the STYPE from the
source object’s SCSTYP attribute.
This is accompanied by a Report Action that will output an error message in the Compare report if the flow direction is reversed.
A Report Action is used when the check required includes an expression based on 3D data, whereas an
Assign Rule compares the whole value of a 3D attribute to an expression based on schematic data. The following example uses a Report Action to check a substring of a pipe name. In this example the PIPE name follows the convention Size-Fluid-Area-LineNumber and the SCPLIN name follows the convention Unit-Size-Fluid-Spec-LineNumber. To compare the Fluid requires a Report Action with
Condition:
An appropriate Mismatch Report would be ‘Fluid code does not match’. If the condition evaluates
false, then this message will be output in the report. Note that there is no output if it evaluates
true.
