Figure 6:12.
Figure 6:13.
Figure 6:14.
Assignee is the object that has the attribute whose value is being set or compared. Allowable entries are:
target - the target object in 3D, this is the usual setting
owner - the owing ZONE in 3D, described below in the example for NAME
root - the owning SITE in 3D, described below in the example for NAME
Figure 6:15.
Build Action is the action carried out during a Build operation. Allowable entries are:
set - set the value of the attribute
ignore - do not set the value of the attribute
Figure 6:16.
Compare Action is the action carried out during a Compare operation. Allowable entries are:
match - the value of the attribute must match the value generated by the rule
matchorexceed - the value of the attribute must be equal to or greater than the value generated by the rule
matchornotexceed - the value of the attribute must be equal to or less than the value generated by the rule
matchaskeyattribute - the value of the attribute will be used to find matching objects in 3D; where key attributes are defined in the rules for a particular type, all their values on a particular object must match the values generated by the rules, in order for the 3D object to be identified as a match for the source schematic object
ignore - the value of the attribute will not be compared
Figure 6:17.
Mismatch Severity determines how a mismatch is reported during a Compare operation. Allowable entries are:
critical error - the mismatch will be reported as a critical error, indicated by a red blob icon in the compare report
error - the mismatch will be reported as an error, indicated by a red dot icon in the compare report
warning - the mismatch will be reported as a warning, indicated by a yellow triangle icon in the compare report
information - the mismatch will be reported as information, indicated by a blue "i" icon in the compare report
Figure 6:18.
Mismatch Report is an optional text that will be output as a line in the compare report following the line on which the mismatch itself is reported.
Figure 6:19.
Name rules based on target are not well supported in Integrator as target is undefined until it is actually created. In some cases it defaults to the source object for data if the target object is not available at that point. Consider an owner rule for building a ZONE when source is SCPLIN and target is the PIPE. It would seem reasonable to set the value of the ZONE name based on the SITE name plus a prefix, e.g. ”format(‘{0}-{1}’, owner of owner of target, LNTP of source)”. But the ZONE is created before the target exists and so this rule will not give the desired result.
Figure 6:20.
Figure 6:21.
