Operators eq, ne, lt, le, gt, ge, test for equality, inequality, less than, less than or equals, greater than, greater than or equals, and apply to a pair of numerical expressions or a pair of alphanumeric expressions or a pair of Boolean expressions. (The result will be unpredictable if expressions of different type are compared.)
Operator not is used to negate the Boolean expression that follows it.
double Sine (double angle)
double Cosine (double angle)
double Tangent (double angle)
double Acosine (double value)
double Atangent (double value)
double Sqrt (double value)
double Log10 (double value)
double Logarithm (double value)
double Alog10 (double value)
double Alogarithm (double value)
double Absolute (double value)
integer Fix (double value)
integer Ceiling (double value)
integer Round (double value)
double Atant (double x, double y)
double Minimum (double a, double b, …)
double Maximum (double a, double b, …)
integer Length (string text)
integer Occurs (string text, string sub)
integer Instring (string text, string sub)
string Asstring (object value)
double Asreal (object value)
boolean Asboolean (object value)
string Substring (string text, integer start [, integer length])
string Left (string text, integer length)
string Right (string text, integer length)
string Before (string text, string sub)
string After (string text, string sub)
string Uppercase (string text)
string Lowercase (string text)
string Trim (string text)
string Lookup (string dictName, string key)
Integer Listposition
// the list order position of the current target element.
