Integrator can build in the current SITE and ZONE if there is no rule to define the SITE or ZONE. In order to get Integrator to build in the current ZONE, use the Main Table Context Menu > Build. If you click in the Diagram Viewer to use its context menu, the current element will be changed to the schematic object, and Integrator will no longer be able to build in your intended ZONE.
On build, Integrator automatically copies over the value of any attribute that appears on both the schematic and 3D object, e.g. Description. The exact set of attributes varies according to type. You can suppress this by creating an Assign Rule for that type and attribute and setting its Build Action to ignore. Refer to How to Configure Build Rules for more detail.
