1.
Accept Differences: A pair of linked objects having differences such as attribute values, sizes, connections or sequence, can be accepted as different.
2.
Accept Missing Element: For unmatched objects, such as a drain connection, the corresponding elements can be accepted as missing. Integrator will still match the object if it is added subsequently to the model.
3.
Disable Matching: For objects that should not be matched ever, such as a tee for a trunnion, whether or not Integrator has currently matched them, matching can be disabled.
