Schematic 3D Integrator User Guide
Integrator Functions in Detail : Integrator Database Administration including Global Projects
All Integrator users require write access to a single CYMWRL. If this is not present when a Build or Link function is performed then Integrator will return an error. Project administrators are recommended to use the following procedures:
Use Manage Links to create a Link World in the new database, or to merge links from an old link world (prior to 12.1 link worlds resided in Design databases).
If using extract databases, then in AVEVA E3D™ DESIGN or Marine Outfitting, use the Extract Control form to select the existing CYMWRL and issue all changes. Repeat this step for all levels of extract database. The next step should then be carried out in the parent database.
In AVEVA E3D™ DESIGN or Marine Outfitting, use Manage Links to merge links from the Design database to a new Design Reference database (e.g. by drag and drop). Then click on the Design database and delete the old Links.
