Schematic 3D Integrator User Guide
Integrator Functions in Detail : Concepts : Schematic to 3D Links
Integrator maintains its links as separate CYMLNK objects against which it can hold important information. Each CYMLNK object has attributes deslnk referencing the 3D model object, and schlnk referencing the schematic object. The CYMLNK object also holds a cmpstatus attribute to record its compare state. The 3D model and the schematic objects both have a cmplnk attribute referencing the CYMLNK object.
Figure 5:2.
CYMLNKs also have attribute englnk referencing engineering objects, but this is not used directly by Integrator.
To simplify navigation between corresponding schematic and 3D objects, Integrator provides the pseudo attributes schlnk and deslnk directly between these two objects. The pseudo attribute cmpsts returns the compare status description on the CYMLNK object or on any linked schematic or design object, or on its linked ancestor. It is included by default in the Integrator Main Table.
