The Pick Connection form lists the 3D branches that have unresolved connections. When a branch is selected in the
Unresolved Branches list, Integrator does the following:
The Connection columns show which branches are connected to which nozzles.
To change the specification reference of a nozzle, select the nozzle in the Connections list, then click on the
Modify Specification button. This will show either the Pipework Nozzle Specification form or the HVAC Nozzle form, as appropriate. You can also create new nozzles and delete existing ones using the buttons on this form. After making any changes, use the
Refresh Lists button to update the form.
To change which unresolved branch is connected to which nozzle, select the branch in the Unresolved Branches list, select the nozzle in the
Connections list, then select the
Set Connection button. The selected branch will be connected to the selected nozzle.
