Schematic 3D Integrator User Guide
Getting Started : Build a 3D Object
Hint: If the Build option is not activated, this may be because the schematic equipment has not been released for 3D in the schematic database. The releaseto3Dstatus attribute can be set in AVEVA Diagrams or Schematic Model Manager. If set via syntax use RESTAT 1.
Figure 3:9.
Figure 3:10.
Equipment built will be listed on the Equipment Details form. From this form you can change the equipment specification and position, and set connection details.
