The user must select Remove from list from the menu display to remove the selection from the
Branches to Split list.
In the Spilt Pipe Options part of the
Spilt Pipe window, the user must now choose how the pipe is split, dependent upon which option the user chooses determines the options available from the
Spilt Pipe window.
Split Pipes on a Plane - Splits the pipe by inserting an pipe assembly at the point a cutting plane (which is created, defined and positioned by the user) intersects the pipe. Refer to
Splitting Pipes with a Plane for further information.
Split Pipes into Segments - Splits the pipe into a number of segments using the dimensions input by the user. The split is defined between two points that are selected by the user (selection of these points can be achieved by the user choosing either the
Feature pick or
Component pick from the
Split By drop-down list). Refer to
Split Pipes into Segments for further information.
Split pipe by moving Component - Splits the pipe at the split point and inserts an pipe assembly at that point. The down-stream components in the branch are then be moved. Refer to
Component Creation Options for further information.
Select the Split Pipe on a Plane check box to display the relevant options in the
Split Pipe window.
The Plane definition part of the
Spilt Pipe window allows the user to define, position and create the cutting plane.
Input the required Plane size in the
Plane Size field, the user can then position the plane:
To create and modify the plane, select Define Plane, the user is prompted to select an design element in the 3D graphical view.
By default the Pipework application displays the plane as a filled representation centred around the defined plane origin. The
on/off check box shows or hides the plane, however the
on/off check box is automatically selected when the plane is modified.
The user can change how the plane displays, from the Plane definition part of the
Split Pipe window. In the
Plane Size field, increase the size of the plane and click to clear the
Fill check box. The plane display is increased in size and as a wire line representation.
The plane can be positioned explicitly: from the Plane definition part of the
Split Pipe window, enter the coordinates in the position fields, if required nudge the plane along with the left and right arrows. The nudge distance is controlled by the nudge increment which is set to 100mm by default. The plane direction can be changed by inputting a valid direction in the
Plane Direction field.
The user can choose from a list of available assemblies in the Filter Assemblies By part of the
Split Pipe window. The assemblies available for selection are those already created in the database, if the user requires an assembly which is not included, refer to
Pipe Assemblies for further information or the system administrator.
Click Split to display the
Confirm window, the split is labelled in the 3D graphical view.
The user can also split pipes using a defined plane by directly picking pipes using the mouse cursor. Click ID Split and then use the mouse cursor to select pipes that are split relative to the existing plane.
Esc must be pressed to exit this mode.
Click Flow to display the direction of flow for the selected pipe.
Click Undo to discard any inputs or
Dismiss to close the
Split Pipe window.
The user can use Split Pipes in Segments, to split a single branch into segments of a user-defined length between components or features picked by the user in the 3D graphical view (at each split, the choose pipe assembly is inserted). Select
Split Pipes into a Segments from the
Split Pipe Options on the
Spilt Pipe window to display the relevant options.
In the Split Pipe Length drop-down list select
Segment Length or
Cut Pipe Length:
Segment Length: allows the pipes to be split into segments of a particular length between selected components or selected features that are adjacent to the pipe. The split is made by inserting pipe assemblies into the branch. Tube length around bends and elbows is calculated as the centreline length.
Cut Pipe Length: (Used for spool length): allows the pipes to be cut at a particular length between selected components or selected features that are adjacent to the pipe. The cut is made by inserting pipe assemblies into the branch. Tube length around bends and elbows is calculated as the centreline length.
Minimum Final Tube Length - restricts the length of the final tube to the final length value. If the final tube length is below this value, the previous spools are adjusted to make the final length within its tolerance.
The downstream components at each split may be inserted into the existing branch, a new branch or a new pipe depending on what the user chooses from the Move down-stream components to part of the
Spilt Pipe window. If a new branch or pipe is requested, the new items are given a default name based on the pipe name.
The user must select the assemblies to insert into the branch where the split occurs, refer to Pipe Assemblies and
Assembly Build Origin for further information. Click
Spilt to split selected pipes using components (refer to
Component Picking for further information) or selected features adjacent to the pipe (refer to
Feature Picking for further information).
To make a split using picked components, the user is prompted to identify start of range selection to select: in the status bar of the 3D graphical view, to start of the range.
After making the selection, the user is prompted to identify end of range selection to select: in the status bar of the 3D graphical view, to end the range. Once the range has been identified, the software then automatically selects the required generic type component in the current specification. If there is a choice of component and the specification does not have a default, the
Message window displays.
Click OK to display
the
CHOOSE window.
Click OK to select the alternative component and close the
CHOOSE window or
CANCEL to close the
CHOOSE window and stop the splitting process.
To make a split using picked features adjacent to the pipe (for example - reference to other parts of the model such as structural steelwork). The user is prompted to identify branch to split in the status bar at the bottom left hand corner of the 3D graphical view. After making the selection, the user is prompted to
Pick the starting component, this can be a component or a feature, this is then labelled as the start and the current direction of flow displays. It is possible to split from either end of a pipe.
The user is then prompted to Pick the ending component or <esc> to split branch: after making the selection, the user is prompted to
identify section of branch where split will intersect.
Click OK to display the
CHOOSE window.
CHOOSE window or
CANCEL to close the
Click Flow to display the current direction of flow,
Undo to discard any changes in the 3D graphical view or
Split Pipe window.
To make a split by moving a component, select Split pipe by moving component from the
Split Pipe Option part of the
Split Pipe window. Once the selection has been made, where to move the components down-stream of the split (selection) must be selected. After selecting to where to move down-stream components. Click
Split.
The user is prompted to identify branch to split in the status bar at the bottom left hand corner of the 3D graphical view. After making the selection the user is prompted to
Pick the piping component.
