Global User Guide
Global Daemon Messages : Progress Messages
If the daemon is running but there are problems with the data it is receiving, you may need to contact your AVEVA Support Office. You may be asked to generate more information about the problem using the options on the Local Daemon Settings form, displayed when you select Settings > Daemon Settings on the main ADMIN menu bar. If it is necessary for you to use the form, refer to the on-line help for further information.
