Global User Guide
Local Administration
: Data Recovery
Data Recovery
If a database has been corrupted, you can recover the data by transferring a complete database from another location. You can specify a neighbouring location from which the data is to be recovered.
This operation is very similar to synchronisation, except that complete databases are propagated instead of updates. It is not available at off-line locations.
It is important to remember that recovering a database could result in loss of work. The main object when a recover is carried out is obviously to restore the database and minimising the work loss.
The database may not become up-to-date immediately, but it will be updated in the normal course of updates, or it can be synchronised with the primary location once the file is re-established.
The user can remotely recover databases from the Hub, the Satellite itself or from the administering location, using the
Remote > Recover Database
option. The window is similar to the
Recover Databases
window for the current location, described in
Recover Database Window
