Global User Guide
Hub Administration : Remote Operations
The options under Remote on the main ADMIN menu enable a System Administrator at the Hub or a Satellite to carry out administrative functions for constructor databases at Satellite locations. The constructor database for an administered location must be Primary at the administered location. The ADMIN daemons must be running.
From the ADMIN menu bar, set the Administering option gadget to the location where the user wants to administer databases, then select the appropriate Remote option. The options are as follows:
The effects of these operations are the same as if they were carried out locally. Generally, use the Remote options from the Hub, the Satellite itself, or the administering location. However, you can use Remote > Integrity Checker from any location.
