Global User Guide
Hub Administration : Changing the Hub Location
Make sure that the daemon is running at both the current Hub and the Satellite which will become the new hub by selecting Query > Global Status > Communications or by issuing a Ping command. This can be achieved from the Admin, Model, Draw or Spool module.
1.
Make sure that all databases are allocated to the new Hub by using one of the Data > Database Allocation options. (This must include all transaction databases.)
In the event of failure, use the Data>Recover>Hub Location option which will be available at the original Hub location. Try again when communications have been restored. The Hub recovery option should be used with extreme caution, as otherwise it is possible to end up with two Hubs. If this happens, no other administration should be done until the situation is resolved. Refer to Running Global Projects for further information
Recovery of a hub location is normally done automatically if a hublocation operation fails - check the progress of the command in the transaction database. An explicit recover operation applied to a hub location Db should only be used as a last resort. It is normally only required when daemons are down or for offline locations. (Refer to Administrator Command Reference Manual (HUBLOCATION and RECOVER, commands)).
