Global User Guide
Hub Administration : Database Allocation : More Notes on Allocation
Check that the allocation has completed successfully. If you select DB & Extracts from the Admin Elements window, a list of all the allocated databases is visible.
Do not attempt to re-allocate a database unless you are sure that the allocation has failed ‑ check that there is no entry in the transaction databases (by selecting Utilities > Transactions to display the Command Transactions window) at either of the locations affected by the allocation.
