Global User Guide
Hub Administration
Database Allocation
: Checking Database Allocation
After every allocation operation, the user should GETWORK and then check to see if the databases have been allocated successfully (as described in the next section). Remember that this will take time: it is not instantaneous. Refer to
Global Daemons
for more information about how the Global daemon works.
When databases have been successfully allocated to a location, other tasks can be carried out. For example, the Hub Administrator can make the database primary at the location, and the Satellite Administrator can add the database to MDBs.
