Global User Guide
Setting up a Global Project : Running the Global Daemon : Using the admind command
If transfer of other data files is required (refer to Transfer of Other Data), then import (IMPORT) and export variables (EXP_XYZ for export to location XYZ) must also be set up.
set AVEVA_DESIGN_EXE=base product install path
set ABC000=%AVEVA_DESIGN_EXE%\projects\abc000
Check whether the daemon is running by starting up the Task Manager and selecting the Processes tab. Look for the process named admind.
base product install path\admind stop prj
where prj is the project code. For example:
base product install path\admind stop ABC
