Global User Guide
Setting up a Global Project
: Installing a New Project at a Satellite
The user can only start the Global daemon at a new Satellite and use the automatic update system once the System databases are available at the Satellite. Initially, the user must therefore copy databases to a new Satellite by some other method; for example, FTP or a DVD.
Locations must be installed in descending order: that is a location must be installed before any of its children.
Once the project has been installed at the new location, the next steps are to start the Global daemon (see the following section) at the new location, and then to
initialise
the location (refer to
Initialising a New Location
). Then the Administrator at the Satellite can create Users and MDBs.
If simulating the Location creation as a training exercise, copy the files to another directory on your local network. Set up the normal project directories and set the project environment variables, as if working at the new location.
