Global User Guide
Setting up a Global Project : Before Creating Location Files
1.
Set up a transfer directory at the Hub which will contain all the files for transfer to the new location. The files needed for the location are copied into this directory, ready for transferring to the actual location.
where XXX is the project code, in this case ABC, and LOC is the location identifier, in the following example OXF, which specifies where to create the location. This variable must point to the pathname of the transfer directory for the new location.
base product install path\projects\transfer
set ABC_OXF=base product install path\projects\transfer
