Global User Guide
Concepts
Propagating and Non-propagating Files
: Working Extracts used as Non-Propagating Databases
The user can create non-propagating databases for local use at a Satellite, which are never propagated. Like all databases in a Global project, they can only be created at the Hub, where they are flagged as non-propagating. They are then allocated to the primary location where write access is required. Even though they are not propagated, they must still exist at all locations in the communications network between the primary location and the Hub.
By default, all transaction databases are treated as non-propagating databases, and are only allocated at the Hub and the owning location.
