Global User Guide
Concepts : System and Global Databases
The Hub is the location where the overall project administration takes place. It is the only location where the user can create and modify:
Each location, including the Hub, also has its own System database. Each System database is propagated to all locations automatically, even if the System database is administered locally. A Satellite System database can be modified by an Administrator who is at the primary location for that database. The primary location can be the Satellite itself, or it can be a remote location, such as another Satellite or the Hub. If the primary location is remote (not at the Satellite itself) an Administrator at the Satellite cannot modify the Satellite’s System database. The Hub System database, like the Global database, can only be modified at the Hub.
The local system database filename is of the form prjsys, where prj is the project code. There will also be a file of the form prjsys_loc for other locations: this is for use in centralised administration (i.e. where one location administers all of the other satellites remotely.).
When the user makes a project Global, a transaction database is also created, to store details about the progress of issued commands. Global provides a facility so that the user can monitor the progress of Global commands, and, if necessary, cancel commands that have not been carried out yet. Refer to Monitoring Command Progress for further information.
