Global User Guide
Introduction
: How to Use This Manual
The Global User Guide is divided into the following sections:
Overview of Global
is an overview of the application.
Concepts
describes the basic concepts of using AVEVA Global.
Setting up a Global Project
is a step-by-step description of how to make a Global project, starting from a standard project.
Hub Administration
describes how to do the tasks that the Administrator at the Hub will need to carry out once the Global project has been created.
Local Administration
describes how to carry out the tasks that all Administrators will need to do.
Monitoring Command Progress
describes how to monitor the progress of Global commands and, if necessary, cancel commands.
Global Daemon Messages
describes some of the messages that may be output by the Global daemon if there is a problem with the communications links between Locations.
Off-line Locations
describes how to set up and administer the communications for off-line Locations.
