Global User Guide
Global Scheduler
The Global Scheduler allows Project Administrators to better manage Distributed Extract Hierarchies. It is possible to configure the scheduler to run key extract operations without needing Designer interaction. It also reduces the amount of Global and Extract knowledge required by the Designers in Plant development. Once the Designer has completed an operation and it needs to be transferred. How and what time the data is transferred is controlled by the Project Administrator by setting up a series of regular scheduled Extract Operations that are managed by the Global Scheduler. Schedules can be set-up to run on a regular basis, with little or no further administration tasks needed.
Controlled Data Item Transfer is only available in Model. Refer to Common Functionality User Guide (section Global).
