Global User Guide
Off-line Locations : Creating Off-line Locations
Locations are created as off-line locations by setting the Off-line option on the Generate Location window. Refer to Creating Location Files. A project is installed at an off-line location by transferring the files from the Transfer directory in the same way as an on-line location. Off-line locations do not require initialising, and you do not need to start up a Global daemon.
