Global WCF
Configuration Guide
WCF Configuration Files
Configure Security
: Message Level Security with Certificate based Authentication
In addition to Windows Authentication, Message Level Security can be configured to use an SSL certificate to authenticate the exchange of messages.
Message Level Security with Certificate based Authentication is a more complicated option compared to Windows Authentication. There can also be a loss in performance based on the size of the message and strength of the SSL certificate used for authentication.
The following setting must be consistent within the
GlobalWCFClient.config
and
AdmindWCF.exe.config
files.
security
authenticationMode
MutualCertificate
requireDerivedKeys
false
messageProtectionOrder
SignBeforeEncrypt
messageSecurityVersion
WSSecurity11WSTrustFebruary2005WSSecureConversationFebruary2005WSSecurityPolicy11BasicSecurityProfile10
secureConversationBootstrap
security
The
Security
parameters are described below:
authenticationMode
How the certificate is authenticated
requireDerivedKeys
Required security setting relating to Certificate keys
MessageProtectionOrder
How the message is signed
Determines the Web-standards to apply to messages
The following block is specified in the Service behaviour and must be modified in the
file.
The user must specify:
httpsGetEnabled
Must be set to true
trustedStoreLocation
The location of the trusted store for the certificate
findValue
Certificate identifier within the trusted store
x509FindType
The type of find value for the search
storeLocation
Certificate Store: localMachine/Currentuser (determined by the certificate).
<serviceBehaviors>
<behavior
name
GlobalWcfServiceBehavior
<dataContractSerializer
maxItemsInObjectGraph
2147483647
<serviceMetadata
httpGetEnabled
true
<serviceDebug
includeExceptionDetailInFaults
true
<serviceCredentials>
<clientCertificate>
<authentication
LocalMachine
certificateValidationMode
None
"></authentication>
</clientCertificate>
<serviceCertificate
findValue
tempCert
x509FindType
FindBySubjectName
storeLocation
LocalMachine
</serviceCredentials>
</behavior>
</serviceBehaviors>
The
file has an equivalent
endpointBehaviors
element that must be modified to match the configuration changes made in the Service Behaviours of the
file.
To view an example of configuration files with Message Level Security using Certificate based authentication, extract the contents of the
GlobalWCF_SampleConfigFiles
folder file and navigate to the sub folder
MessageSecurityCertificateAuthentication
