Global WCF
Configuration Guide
WCF Configuration Files
Configure Security
: Message Level Security with Windows Authentication
Message level security can be enabled for scenarios where Global daemons need to make sure each message exchanged is protected. Windows authentication can only be used where the Global daemons are deployed in same domain or in two trusted domains.
The following setting must be consistent within the
GlobalWCFClient.config
and
AdmindWCF.exe.config
files.
security
mode
="Message">
<transport
clientCredentialType
Windows
proxyCredentialType
="None" realm="" />
<message
Windows
negotiateServiceCredential
true
algorithmSuite
Basic128Sha256Rsa15
establishSecurityContext
true
security>
To view an example of configuration files with Message Level Security using Windows authentication, extract the contents of the
GlobalWCF_SampleConfigFiles
folder
file and navigate to the sub folder
MessageSecurityWindowsAuthentication
