Global WCF
Configuration Guide
Software Checklist
: Microsoft .NET Framework v4
Windows Communication Foundation (WCF) is a feature that is provided with the Microsoft .NET Framework.
To be able to run the WCF Global Server the user should check that the Microsoft .NET Framework 4 has been installed onto all Global daemon computers. This is normally done as part of the installation process.
The appropriate version of Microsoft .NET Framework is also required on base-product installations required to initiate a Global operation.
The 12.1.SP4 base product (Plant/Marine/Engineering) requires Microsoft .NET Framework 3.5 SP1 rather than Microsoft .NET Framework 4.
The base product is installed with the appropriate .NET Framework incorporated and should be consistent on all computers that Global is deployed to.
