.NET Customisation
.NET Customisation
: AVEVA C# Grid Control
This section describes how to use an instance of an AVEVA C# Grid Control on a C# form. The example which is used in this documentation is supplied with the product. The Visual Studio project containing the source code is located in the following directory:
Samples\NetGridExample
That you can only use the AVEVA C# Grid Control on your own Visual Studio form if you have a design time license for Infragistics.
That you can run this C# Addin with AVEVA E3Dâ„¢/Marine without having an Infragistics license.
