.NET Customisation
.NET Customisation
: Menu and Command Bar Customisation
User access to functionality provided via an addin is normally provided through the use of menus and/or tools on a commandbar. Reference was made earlier, in the section about addin commands, that the CAF provides a mechanism to allow the menus and commandbars for an application to be defined in a "User Interface Customisation" (UIC) file. This section provides details of how a CAF based application can be configured to load a UIC file, and how the UIC file can be edited using the applications interactive user interface customisation tool. Newer modules, for example MODEL and DRAW use the new Ribbon commandbar, this is configured in the same way as the original toolbar (detailed below).
