CommandBarManager: This provides access to the menus and commandbars of a CAF based application. It also has methods to load the definition of menus and commandbars from User Interface customisation (UIC) files.
CommandManager: This class defines an interface to provide the presentation framework client with a mechanism for the management of command objects which can be associated with Tools or other User interface objects. The action of invoking a tool (e.g clicking a ButtonTool) will cause the execution of the associated command object. It is possible to associated the same command object with a number of different user interface objects (e.g. ButtonTool on a Menu and a LinkLabel) thereby allowing for the centralisation of these user interface objects action within a command. Various state-like properties of a command (e.g. enabled/checked) would also be reflected in all user interface objects associated with a command. For example, disabling a command would cause all associated user interface objects to be disabled. User interface objects are associated with a command via a CommandExecutor derived class.
ResourceManager: This class defines an interface to provide Addins with a simplified mechanism to access localizable resources.The ResourceManager provides a number of methods which allows an addin to then access the various types of resources (string, image, cursor, icon etc.) which resource files may contain.
WindowManager: This provides access to the main application window, the StatusBar and a collection of MDI and docked windows. It also provides the addin writer with methods to create MDI and docked windows to host user controls.
