Clash Manager
Performance Hints
Clash Manager Functions
: Loading a Desclash Report File
This process enables a desclash report (created by running Clash Manager) to be loaded directly into the Clash Manager database, without re-running the Clash Set. It may be used, if following a lengthy desclash run, the normal loading process is interrupted.
The equivalent process can be initiated by the
Load Clash File
button on the Clash Manager Options form - 'Advanced tab.
Note that only desclash report files created by running Clash Manager should be loaded using this option.
Phase two of the loading process may be omitted (by using the -L option). Phase two comprises Setting Clash Group Level Type Worst cases, Garbage Collection (including removing unwanted historical data, configured as part of the Clash Set definition) and finally Updating Element worst case Clash State. This option may be used when loading several files, but the last execution should not include the option, since it is most important that Phase two of the loading process is executed.
Note that the required environment must be set prior to executing the software with this option, for example by calling evars.bat from the PDMS installed folder.
Syntax
The syntax is:
Mmscmd <userid> <password> <connectString> <project> <configFile> <logfile> -clash loadFile <set_number> "<comments>" <clashFileName> [-L]
Example
call c:\Aveva\pdms12.0\evars.bat c:\Aveva\pdms12.0
rem following command line shown on several lines for clarity
c:\Aveva\ModelManagement12.0\mmscmd enr1 secret van1 sam
c:\Aveva\projects\sam\samdflts\sam.cfg
c:\MMS\logfiles\log.txt -clash loadfile 1 "clash set1"
C:\Temp\pclam_SAM_cadusr_1\pclam_0001.OUT
