Clash Manager
Performance Hints
Clash Manager Functions
: Running a Clash Set
Running a Clash Set
The complete process, using MMSCMD, is identical to performing the task manually using the standard GUI. Indeed, during the run, the standard RUN CLASH SET GUI is displayed enabling, for example, the run to be cancelled.
The desclash module of design is run with the Check List, Obstruction List and Exclude Lists derived from the nominated clash set. Defined Gap and Clearance, Bcheck options, etc, are also included.
A separate desclash report file is generated for each Check List item. The generated desclash Report File(s) are loaded into the Clash Manager database.
Acceptance and Assignment rules are applied to new clashes to automatically set Clash Status and Discipline ownership.
In the final phase, after all desclash Report File(s) are loaded, Clash Group Level Type Worst cases are set, Garbage Collection is performed (including removing unwanted historical data which is configured as part of the Clash Set definition) and lastly Element worst case Clash States are set.
Note that the required environment must be set prior to executing the software with this option, for example by calling evars.bat from the PDMS installed folder.
It is common practice to schedule smaller clash sets to run overnight during the project working week and an overall clash set to run each weekend. Also, it is recommended that only one batch of clash sets is run at a time, otherwise contention for access to clash records can occur.
Syntax
The syntax is:
Mmscmd <userid> <password> <connectString> <project> <configFile> <logfile> -clash set <set_number> "<comments>"
Example for Oracle
call c:\Aveva\pdms12.0\evars.bat c:\Aveva\pdms12.0
rem following command line shown on several lines for clarity
c:\Aveva\ModelManagement12.0\mmscmd enr1 secret van1 sam
c:\Aveva\projects\sam\samdflts\sam.cfg
c:\MMS\logfiles\log.txt -clash set 1 "run clash set 1"
Example for SQL Server
call C:\AVEVA\plant\pdms12.0\evars.bat C:\AVEVA\plant\pdms12.0
C:\AVEVA\MM12.0\mmscmd.exe PCLAMSAM PWSAM
"SqlOleDB.1;AVEVA-I2VRIIWLV\CLASH01;CLASHDEMO" sam
C:\AVEVA\plant\PDMS12.0.2\project\Sample\samdflts\CLASH_SAM.cfg
C:\AVEVA\plant\PDMS12.0.2\project\Sample\samdflts\log.#date##time#.log
-clash set 25 "TESTCMD"
