Clash Manager User Guide
GUI : Test Rules Form
Group / Detail radio
group and Element
Name % Wildcard
Index (clash details
only)
Blank after Query. Populated after rule evaluation. Shows owner discipline as assigned by the new rules. The name of the rule is shown for NEW clashes only.
Blank after Query. Populated after rule evaluation. Shows the status as applied by the new acceptance rules. The name of the rule is shown for NEW clashes only.
Populated after Query. Shows the clash level.
Populated after Query. Shows the clash type.
Blank after Query. Populated after rule evaluation. Shows a narrative description of the clashing elements.
The procedure for using the form is firstly to select clash group or detail and enter an element name and wildcard to represent elements that will be affected by the updated rules. Initiate the Query and then check the displayed records to make sure that they represent the required typical elements. If they do not, re-enter element and wildcard details and re-query the data. When the records are as required, apply the new rules and check whether the results are as required. If the PDMS Model has recently been changed, use the 'Get Work' feature and repeat the evaluation. Close the form by clicking on the X at the top right-hand corner. Take action at the 'Clash Manager - Configuration' form to correct or implement the new rules, as appropriate.
