Clash Manager User Guide
GUI : Clash Manager Configuration Form : Assign
Each Rule in the Discipline Assignment Rules consists of a number of 'Rule Expressions'. Rule Expressions, which are formed of certain keywords, literals and regular expressions (wildcards), are described under Notes on Rules and Rule Expressions. The first discipline with a Rules whose Rule Expressions all evaluate true becomes the owner discipline, by default. Alternatively a setDiscipline keyword operator may be used in a rule expression to assign the owner discipline to that of one element or the other, or even to a third unrelated discipline.
Up and Down
Rules
pane showing a
hierarchy with Discipline
as the primary nodes
which, when expanded,
display the applicable
Assignment Rules
A Popup Menu is available (mouse right-click) with options of Edit, Add and Delete. This is used to edit an existing rule name, add a new rule, or remove an existing rule.
Up and Down
Lower pane showing a list
of Rule Expressions under
Element, Attribute and
Value headings
Popup Menus (mouse right-click) are available from the three components of the Rule Expressions. (Note that the current options are omitted from the editing options of the displayed menus and that the Esc key can be used to abort the entry in an in-place options box.)
The Element Popup Menu options are:
Editing options - @element-1, @element-2, @general
Add Rule
Delete
The Attribute Popup Menu options are:
Editing options - @discipline, @class, @priority, etc, and
@gtype
Edit - leads to in-place editing options box
Add Rule
Delete
The Value Popup Menu options are:
