Clash Manager User Guide
GUI : Options Form
This form consists of two tabs called Preferences and Advanced. Below the tabs are OK and Cancel buttons for respectively implementing or ignoring any changes made.
Caution: It is recommended that this option is set to True. If it is set to False, clash recomputation with the 'Clash Group Status from details' option selected (see Clash Recomputation form) may reset the status of all clash groups to the status of their worst case clash details.
Clash Check CE (leading to
Display Report and Retain
Filter
options)
Large Transactions
leading to Warnings and Worst Case Update Threshold options)
Warnings (record
counts...)
(leads to further options
see next column)
Clash Details from Selected Groups (default 1000)
3D View from Selected Groups (default 10)
Claim/Flush/Issue/Edit/Select All (default 100)
(See Large Transactions below.)
Clash Details from Selected Groups - this operates when Auto Display Clash Detail has been selected, clash details are being viewed and the total number of clash groups selected exceeds the set value.
3D View from Selected Groups - this operates when clash Auto View has been selected and the total number of clash groups selected exceeds the set value. (Note: Warnings of both Clash Details... and 3D View... may be displayed. This gives the user the opportunity to perform or cancel one or both operations.)
Claim/Flush/Issue/Edit/Select All - this operates when any one of these actions is initiated for a number of clash groups that exceeds the set value. The setting also determines how many records can be present in the active pane of the 'Clash Report' window before the Select All option of the Edit menu is greyed out.
