Clash Manager
GUI
Clash Report
: Edit
Edit
This menu operates on the Active pane. The available options and their purposes are:
Select All
Selects all tabulated items in the report. Is greyed-out if the number of records in the active pane exceeds the
Large Transaction> Warnings>Claim/Flush/Issue/Edit/Select All
setting at the 'Clash Manager Options' form.
Remove Selected
Removes the selected items from the report.
Operations on all clashes in the active pane, such as display, or approve are still applied to the removed items. They are only removed from the active pane.
Remove All
Removes all items from the report.
Find
Leads to the standard 'Find' dialog box.
