Clash Manager
GUI
Clash Report
: File
File
The available options and their purposes are:
Save As
Displays the standard saving form. This enables the user to save information in the report as follows:
(Current Pane) Comma Separated (*.csv)
(Current Pane) Tab Separated (*:txt)
(Current Pane) XML (*.xml)
(Current Pane) XML & Stylesheet (*.xml)
Consolidated XML Report (*.xml)
Consolidated HTML Report (*.html).
The first four options (Current Pane) save information, in the stated format, from the Clash Groups report or Clash Detail report, depending on which pane is active.
The final two options save information from both Clash Groups and Clash Detail reports and from the filter pane. The information is presented as a
Consolidated Report
The xml version of the Consolidated report refers to a common style sheet supplied with Clash Manager. The HTML version is a result of processing through this style sheet. Applying the style sheet before output, resolves all problems regarding viewing, saving, copying or emailing, as the HTML version is a self-contained file.
When the 'Save' button on the Standard Saving form is pressed, a 'Report Comments' dialog box is displayed. This dialog box is for entry of any comments that are to appear at the start of the consolidated report.
Refresh
If Clash Groups are displayed, refreshes the groups with the current filter and clears the Clash Detail report.
The 'Auto Display Clash Detail' option on the Preferences tab of the Clash Manager Options form is set to False.
If Clash Detail alone is displayed, refreshes Clash Detail using the current filter.
Close
Closes the window.
