This form is used to add simple items and expressions to the Obstruction,
Check and
Exclude lists on the 'Clash Set Data' form. (The name of the form includes the name of the particular list.)
Note Regarding Modification of Existing Expressions: Prior to the introduction of expressions to the lists, the syntax was limited to wildcards applicable to item names. For example, <wildcard> of <owner>, which if entered as
^/M of WORL would have added all Items under WORL which begin with
/M. This would now be written as an <expressionStypeB>: name like <wildcard> of <owner>, which would be entered as
name like ^/M of WORL. Refer to
Notes on Element Rule Syntax.
