pclam.fin – this file will contain the message ‘OK’ if the clash set processed without error. If an errors occurred during the desclash execution, then the error message text is written to this file.
pclam.log – this file is the main log file and contains messages to indicate the processing of each check element. The foot of the file contains the message ‘Normal Termination’ if the clash set completed successfully.
pclam.mon – this file contains a detailed set of messages and time stamps to indicate duration of each stage of processing and loading of clash output files into the Clash Manager database.
pclam.pmlmac – this is the pml macro executed by the clash set to generate the clash output files
pclam_check.pmlmac – this is the check macro called by
pclam.pmlmac that performs the clash check processing in Desclash.
pclam_nnnn.OUT - this is the output file generated for each checked element.
